Installing transmission?
slow s13
Car: cars, photo, music
I put my SR in without the transmission and am having a hard time getting the trany on. I cant get the ouput shaft into the center of cluch. I can get about an inch away and then the transmission is hitting the firewall. Any tips? Ive tried tiping the motor back toward trany with no luck. I think im going to have to pull the motor and put the transmission on.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
its much easier just to put the whole engine+transmission in together. Sorry i cant give any tips, i have never taken off or put on a transmission from underneath the car.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Yes, I agree it is way way way easier with the transmission already on it. I guess I can try and share a few *off the top of my head* ideas. You can try to unbolt the motor mounts and lift the motor from the front, or you can place a block of wood with a jack to push up on the main pulley. With the motor tilted, you will probably need a second hand or a transmission jack and lift the transmission STRAIGHT UP without tilting etc. I don't see why you would be an inch away because there should be adequate space for the transmission to go a little higher then it needs to. Also, with the shaft in or almost in, you can rotate the tail shaft while it is in gear to position the splines.
slow s13
yeah I tried so many damn things today, I took off the turbo side motor mount and lowered the motor that didnt work, my mounts are unbolted and I tilted it all the way back as far as it would go still not making it, and yeah I dont see why it doesnt fit, I did swap on the SR bellhousing to my KA transmission so maybe the demensions are just a bit different enough where it wont go on. The car is on jack stands and Ive been using my jack to move the transmission around.
