greenwar wrote:Infinitidreams20 - can you please post a picture of exactly where you are connecting the transmission cooler tubes to the transmission? I am thinking about installing a B & M one. Did you have to buy extra tubing or clamps etc.
Also if possible post a picture of the area where you mounted the transmission cooler. I was thinking about somehow placing it somewhere around the condenser or the radiator. I guess there are many options.
nismoChi's cooler is a little larger then mine but yes his hoses are routed the same way his mounting is way different i am worried about using the "ziplocks" through the radiator heard bad stories of after a while rubbing pinholes in the radiator causing leaks so i mounted it with a L bracket on the bottom and mounted it to the core support then used the supplied brackets and just bolted one side to the cooler and one side i used self tapers. And yes the only thing extra i bought was the L bracket $1.99My car is at my parents right now i dont know when you are going to do your job but if you still need pics ill take some this weekend if you want
yodawill2000 wrote:I would weary about routing the tubes under that frame.Maybe weld a U shaped bracket just incase.Just a thought.
they are away from most harm if you are going to hit the lines then you are probably going to cause more damage to worrie about then just the lines
NismoChi clean job none the less good work
