Installing These sideskirts
VietGQ
Car: 89 s13 240sx
how would i install these it has no brackers for the doorjam to install http://img527.imageshack.us/i/090120092 ... 09273.jpg/
Modified by VietGQ at 10:27 PM 9/1/2009
locoluna825
Car: 90 240sx coupe
our pics dont work
VietGQ
Car: 89 s13 240sx
works now updated
locoluna825
Car: 90 240sx coupe
Silvia skirts?
VietGQ
Car: 89 s13 240sx
i dont know i got these for free and im trying to install them but where the doorjam is it doesnt go there so theres a gap
ArcherV20
Car: 1995 240SX
I don't understand what you're saying, but I'd like to help. Take pics of it not fitting properly.
s***ty / No Brand side skirts usually have to be professionally installed as they may require modification to fit properly. Do it wrong and you'll end up with a REALLY bad looking kit man.
Most likely you're going to need to drill some holes into your car to get those on, use a bit of strong double sided tape (3M makes some god stuff) and you should be okay. But in your case where it doesn't line up nice, I'd go talk to a body man first.
Nali
Car: Datsun Nissan 280ZX
To Flame or not to flame??
Im a nice guy
Mount them using the ends. i.e The Fat parts which go into the wheel wells.Not all skirts go under the door jam, some you just mount into the wheel wells. Like these seem to be.
So do that, you might have to drill holes into them, but it isnt unheard of.
Good luck.
ZX88
Car: s13
drill holes at each end. use screw or zipties to hold them there. and double sided tape.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Honestly, see a body shop. If you cant get past the sideskirts, then you shouldnt be doing your own body work. Attach the ends in the wheel wells and put some 3m double sided tape on the edge of the top side.
94_240sx
Car: 94_240SX
VietGQ wrote:how would i install these it has no brackers for the doorjam to install
3M double sided tape should work just fine. Use plenty of them and make sure to heat up with lighter or torch.
