240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Thu Dec 04, 2003 2:56 pm
mine was in the air too. the endlinks werent really too too bad, although i wish they would have tightened more (not that theyre not tight, but they could still be tighter if there were more threads).
i ran out of threads on the bolt because i didnt use the bolts that they came with. the hardest part of my install was bolting the front bar to the chassis with the D bushing(correct name??), if you got the suspension techniques sway bars, the advice i have for you is use the stock bolts that hold the D bushing to the chassis, its stronger and much easier to install (in my case).
