justeller »
https://forums.nicoclub.com/justeller-u235756.html
Sun May 03, 2015 5:24 am
Yes. It's been about 12 years since I've used one of these but it is basically the same as using the rear or single auxiliary lines on an aftermarket HU, with some loss in sound quality. Some aftermarket HU's also have a separate sub output so you can just tweak the sub from the HU, but you will basically have the same as front/rear or single auxiliary setup. So you would want to adjust your sound on the HU for your door speakers, then go to the amp to dial in your sub the way you want it. Someone correct me if I'm wrong, but I think the converter boxes might have had a dial adjustment on them also. I can't remember if it was a l/r adjustment or a frequency adjustment of some kind. But we are talking a decade ago when I did this, I'm sure the boxes are a bit different, but that is the basics. The only other thing is, you do not have a factory amp, correct? I've seen people try to use the converters with factory amps, and the only way It used to work was to tap the speaker wires before the amp, if you were tapping wires that were post amp, I never saw one work, idk if it was the extra watts or what, or just those couple vehicles. But if you don't have the Bose system you should be fine.
