Installing sub and amp w/ stock non bose head unit!!!
All things Altima Coupe.
Eric Noa
Car: White 2011 Altima Coupe 2.5 S 6MT
I want to install a sub and amp with my stock non bose head unit and I was wondering if I need anything special to connect the sub to the radio or is it just a plug and play like aftermarket radios? I've been searching but I can't find anything
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Look in the audio section and do a search. There's been a lot of topics writteen on this. You'll need the basic wiring schematics so you know what and where to tap into.
Eric Noa
dangeris wrote:Look in the audio section and do a search. There's been a lot of topics writteen on this. You'll need the basic wiring schematics so you know what and where to tap into.
Thank you.... I figured it out, by the way the wire colors are completely different for the 2011 model.
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
ur need to purchase a Hi-Low switch that will connect to ur 2 rear speakers + and - its a small box with 4 wires and 2 rca connectors... (no take intrest that when u do this you will pushing out 100% what the sub can put out b.c of the sock head unit, but still works geat... the only wires that r gunn ahve 2 be ran to the front is the Power wire and the remote wire.... Ground: can be groundeded under the back seat.. and like i said the RCAs will connect tor the hi-lo swich that are conneceted to the rear speakers..
Eric Noa
Mattv609 wrote:ur need to purchase a Hi-Low switch that will connect to ur 2 rear speakers + and - its a small box with 4 wires and 2 rca connectors... (no take intrest that when u do this you will pushing out 100% what the sub can put out b.c of the sock head unit, but still works geat... the only wires that r gunn ahve 2 be ran to the front is the Power wire and the remote wire.... Ground: can be groundeded under the back seat.. and like i said the RCAs will connect tor the hi-lo swich that are conneceted to the rear speakers..
Thank you!!
Mattv609
EDITT*****
ur need to purchase a Hi-Low switch that will connect to ur 2 rear speakers + and - its a small box with 4 wires and 2 rca **INPUTS**... (now take intrest that when u do this you will **NOT BE** pushing out 100% what the sub can put out b.c of the sock head unit, but still works geat... the only wires that r gunn have 2 be ran to the front is the Power wire and the remote wire.... Ground: can be groundeded under the back seat.. and like i said the RCAs will connect tor the hi-lo swich that are conneceted to the rear speakers..
SRY I Type too fast some timee... any issues message me.. (make sure pms on)
Eric Noa
Mattv609 wrote:EDITT*****
I will and thanks once again...
dangeris
08 BMW 328xi Coupe
90 300ZX 2+0 NA
And just to add to what Mattv said about the hi-lo converter, make sure you get a PAC SNI-35 or else you'll be sorry. DOn't try to save a few bucks buying a scocshe unit...They're garbage!
Eric Noa
dangeris wrote:And just to add to what Mattv said about the hi-lo converter, make sure you get a PAC SNI-35 or else you'll be sorry. DOn't try to save a few bucks buying a scocshe unit...They're garbage!
Thanks Dangeris! Thats the one I got.
