Installing Solid Motor Mounts
ChampaignSilviaS14
Car: S14
Hey Nico... Im trying to install these solid motor mounts on my 95 S14, but im having trouble figuring out how to jack the motor up right as I don't want to hurt anything but I want clearence to swap out the old motor mounts.Could anyone who has done this or knows how to do this tell me where to jack the motor up at? Thanks!
s13point5
Car: 89 240sx
got a cherry picker? if not get some wood and put it on the jack and raise the motor up by the oil pan being careful that you dont dent it
s13point5
Car: 89 240sx
oh and i hope this isnt your daily driver
ChampaignSilviaS14
Car: S14
Yea its my DD why do you ask?
And I am kind of worried about the oil pan..... I heard some rumor I could use a jack where the transmission connects to the motor?
alexander500
Car: 1997 240sx
You can jack it up there, but if you do jack it up consider loosening the trans mount to allow for movment and so it doesn't bind.
If you put a block of wood inbetween the jack and oil pan to distribute the load there really should be an issue with damaging it. It isn't going to take a tramedous amount of force to lift the engine up a few inches so you can swap the mounts. It is a fairly easy task, so good luck and be safe
dontuhatepants
Car: 93 s13 coupe sr20 etc., 95turboeclipse, 08 CRV
Because solid motor mounts transmit A LOT of vibrations from the engine through the chasis.
dtowndrifter
Car: s-14 kouki
^^^^^^^^^alot, alot of noise with those mounts...^^^^
moulton712
Car: coupe, hatch, both s13s
oil pans works great, just use a good peice of square wood. not like a 2x4, but like maybe 1.5 foot x 1.5 foot or something. what really sucks about this job is the nuts on the lower part of the motor. part of the sub frame is the way and it's had to get some sockets in there. also the nuts were so hard to break away.
i had nismo transmission motor and transmission mounts. one of the bolts on the transmission mount broke when i was installing it. i looked at the ends where it broke and noticed small air bubbles.
ChampaignSilviaS14
Car: S14
Damn... was hoping it would be an easy installation, guess not!
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
yeah it's kind of a PITA. And it sucks for a DD.
My buddy had them in his SRT4 and i hated being in that car cause of the violent shaking.
KLYPH
Car: Brougham
Loosen the trany mounts but not all the way and jack it up from the bell housing. You are going to hate the mounts at first.
AE240SX
Car: '95 Nissan 240SX SE A/T Pearl White
I put hockey puck motor mounts in my car mostly cause like to DIY and cause one side collapsed completely one night so I had to but the pucks aren't too bad for daily use. I get some vibration(sometimes it's alot) but i can't imagine how bad completely solid mounts would be. I would think riding a jackhammer to work might be more pleasant.
To install them i put the car up on jacks on the front and used a piece of wood underneath my oil pan and jacked the motor up one side at a time. I got more clearance one side at a time but you might be able to do both sides at once. You will need a swivel socket/extension though to reach the bottom nuts, other than that it should be pretty straight forward. Watch clearance on the top of the motor as your going up though.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
I followed AZHitman's procedure to make your own engine mounts. yeah it's rougher then stock but it ain't bad.
Anyways for installation it took me ~1 hour. Unbolt both the engine mounts and the transmission mount. Then i used a piece of 4x4 between the AC compressor bracket and the jack. Jacked up that side of the engine, pulled out the factory mount, put the new one in.Dropped it back down(Obviously line up the threaded part with the hole).Go to the other side, use the 4x4 on the alternator bracket, jack up that side of the engine, swap the mount, lower engine.
Then just climb underneath torque both the lower engine mount bolts, then go up and torque the uppers, then reattach the transmission mount. It took ~2 hours of driving for the mounts to settle all the way, so then i went and just retightened everything again and it's been great for the last year.
gregfarz78
Car: 04 Honda S2000
97 Nissan Hardbody King Cab 4x4
09 Nissan Altima Coupe 3.5L
If the OP is talking solid mounts you're going to feel a lot of vibration, I filled my mounts in my spec v about 5 years ago with polyurethane I bought from mcmaster (window weld works too), theres a little bit more vibration but its not that noticeable. The filled mounts do the job the same but they offer a less vibration in cabin. I'd avoid solid mounts on a DD
KLYPH
Car: Brougham
Sell the solid ones and buy the rubber ones from JGS.http://www.jgsturbo.com/ka24et.htmlAllot of people like them. They are much better than Megan or Nismo.
Modified by KLYPH at 2:11 PM 6/15/2008
Kalypso
KLYPH wrote:Sell the solid ones and buy the rubber ones from JGS.http://www.jgsturbo.com/ka24et.htmlAllot of people like them. Much better than Megan or Nismo.
something new!
moulton712
yeah the nismo ones suck, esspecially if they break while installing them.if your motor mounts have never been changed in your car, this is where it becomes harder. took me under an hour in my red car, but took me forever in my white car. cause the bolts wouldn't break free.
ChampaignSilviaS14
Car: S14
Alright thanks guys, Yea I have Solid Aluminum motor mounts haha.
Bumnah
Car: 1992 240SX, black. Bone stock.
i have cusco mounts in my car. they're polyurethane. the car shakes obviously. it's not as bad as people make it out to be. while driving it's hardly noticeable. idle you def. know it's there.
leave loose change in your ash try or something yeah you'll hear it shaking.
if you don't want to be inconvenienced at all then get the nismo stuff.
BlueMellonPop
Car: 1993 240sx
I have the nismo one's and never had trouble installing them in the driveway. My whole dash vibrates, and my b&m shifter rattles more than when I had the old mounts.
FastNFurious
Car: 93 240sx w/SR20DET
I put solid motor mounts (cusco) on my S13 DD. 3 months later, took them out.
Kalypso
I got the project nissan mounts, and one broke while being tightened.
It seems like there are nismo mounts, oem mounts... and everything else is either too hard or too cheap.
is JGS the way?
gene96na
Car: 1996 Z32 convertible
how to install motor mounts on a 1996 300ZX. Is it better to remove the bracket from the engine with the mount attached?
94_240sx
Car: 94_240SX
Kalypso123 wrote:I got the project nissan mounts, and one broke while being tightened.
is JGS the way?
If I can do it again, I would use new OEM mounts filled with urethane.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
gene96na wrote:how to install motor mounts on a 1996 300ZX. Is it better to remove the bracket from the engine with the mount attached?
completely wrong sub-forum. try here .
johnny butt
Car: 1993 240sx Convertible
lol, i was wondering wtf was going on... at least he searched (6/17/08)...sort of...
danielsan
Car: 1991 240sx coupe SE
odd that you didnt ask me man. dont you remember im rocking hockey puck mounts son!! the mounts are really easy to replace. but why are you going solid?? im not going to lie but it gets real annoying after a while. mine are not solid but the hockey pucks are pretty damn stiff and i get no movement at all as you saw a while back.
to jack the engine up i used the ac bracket on the driver side but i can remember what bracket used on the passenger side. im going back to stock and making my own engine damper.
Modified by danielsan at 1:19 PM 1/26/2009
xrproto07
Car: 96 S14 zenki
I am so glad I read this thread about now, I was about to buy nismo motor mounts to replace my oem mounts, but after reading all the experiences with the solid mounts I'll skip the nismo mounts and either new oem mounts or jgs mounts
Justin35ll
Car: s13 coupe sr20det
I was going to do solid, but eh decided on keeping the stockers in for now and save for some aftermarket stiffer ones, but not solid.Didn't want to have to deal with vibrations and **** and it's not even a dd
driftneil
Car: A pile of cars.
To bump a kind of old thread....Does anyone know how to get the mount out of a 91 hatch. I cant seem to get to the bottom bolt??
