babowc wrote:also.. i have no prior experience with the spring compressor.. so i guess that can be a minus, but im no idiot to be looking directly at the springs while im compressing them
It's really not difficult. Kinda like a clamp that compresses the spring as you tighten it. Once the spring isn't exerting any force on the upper mount, you can unbolt it and slowly release the compress spring (then toss it in the trash, or whatever).
If you're replacing shocks and springs, you'll definitely want to replace the rubber boots over the strut piston (they tend to disintegrate in to nothing) and you can get KYB boots for about $11 a piece from Tirerack.
I also replaced my upper rubber mounts with OE replacement-type parts from KYB. Another option would be to get camber plates, like these:
http://www.tein.com/pumnt.html
Less play in them since they're solid aluminum with spherical bearings (only downside would be possibly more road noise, just turn up the radio) and they allow camber adjustment in the front.
