When I purchased my car, I was under the impression from the dealer that I could install roof rails, but was later told that it would have to be done at the factory. I contacted another dealership and they told me that they would be able to install it, however, they needed to verify if there were bolts underneath the roof panel. Since, I had to get it serviced, they said they'll remove the roof panel and check for the bolts. So, when I went to pick up my car, I was told that they would not be able to install the roof rails because I did not have the bolts. I'm still a little skeptical whether or not they actually checked. So, here are my quetions:
1. How difficult would it be to remove the roof panel to check for bolts?2. If it's confirmed that there aren't any bolts, are there any other options to install the factory roof rails? 3. What other options are there for base roof rail system?
Thanks for your help.
