The minimum injector you should run is 550cc. This will keep you from hitting 100% DC and give you just enough head room left over. Personally, I'd choose a 650cc or 750cc injector. You may possibly be able to hit 400whp on the 450cc injectors by raising the base fuel pressure to 56psi (effectively creates a 500cc injector) but the trade off is that you'll lose total flow capability of the fuel pump (fuel pump total flow decreases with pressure).
The following calculators are nice tools to spec injectors for whatever your goals may be. They're theoretical so should be used as a reference.
Target HP Based on Injector Size:
http://fuelinjectorclinic.com/hp-calculator
Fuel Injector Size Based on HP Target:
http://fuelinjectorclinic.com/flow-calculator
reuhzaki wrote:I will do a little more research on injector size in that case. From what I've heard and read so far it should be fine. I can't get pics on here. From what I understand I can cut the were a few inches behind the injector plug, run some gauge wire to and from each individual resistor to each injector and to the wire leading to the ecu right?
Correct, you can mount your resistor box remotely and run the wiring. 16-18GA should be sufficient. You can also install each resistor inline on the harness if you want provided there's space.
