97240SXSE wrote:My question is: What are the symptoms of a misfire or bad connection besides rough idle? Are there any visual clues? The engine runs smooth now, but I've never changed the plugs myself before and I don't have full confidence in my work. I've driven about 30 miles since and noticed the boot on cylinder one lifts about 1mm or 2mm off the motor. Is this ok? Should it be flush?
Other symptoms of misfire are reduced HP and MPG.
I'll assume that you have a 1991 or newer 240SX since you didn't describe your car. The plug boots should never lift at all; it's a point of future failure. Are the plug wires OEM or some aftermarket crap?
It looks like it's time for a new ignition wire set; a good wire set to buy is 'NGK BLUE'; it's an excellent wire set and much cheaper then OEM.
