I did search Nico That where I found this.
zerothread/328196
I might go with what ItzGenX wrote here:
zerothread?id=336036
Offline
Pass Christian, MS9-4-2002Add this post to My Notepad « Re: (240sxvaj) 5:43 AM 5/9/2008
All the motors I've built, I have put brand name conventional oil in. Start it up and run around checking for leaks as it warms up fully. If the car is equipped with a standalone, I usually set up a base map as well while it warms. After about 15-20 minutes of idling and no leaks etc, I pull out of the drive and go balls to the walls. Usually I start off with 1st and 2nd gear at half throttle as I begin to drive off. Then as I decel in second gear with clutch still engaged, I listen for anything off sounding. If none detected before the RPM decel to idle speed, I gun it to redline all the way through 4th gear, then let the engine do my braking all the way down to idle. I do about 4-5 1000rpm to redline pulls in 4th (usually over 100mph for most cars) before bringing the car back for it's first oil change. I always use a magnetic drain plug along with a large 4x4x1 inch magnet I have stuck to the bottom of the oil pan during this break-in procedure. For aluminum pans, I usually use a few bungee straps to keep the large magnet under the pan. This helps keep all the microscopic metallic flakes scrubbed off from the cylinder walls, piston rings, and cams to sink in the sump and stay there, where it can be collected by the oil drain plug. If the pan is a steel oil pan, the whole oil pan bonuses as a magnet too. When draining the oil for it's first oil change, I will notice very very very fine metal particles in a decent amount (indication of cylinder and ring break-in). The key here is to make sure I find no large particles (bearing flakes in particular). Running this stuff between your fingers should feel silky smooth. If it feels grainy, then there's something wrong with the build. If I drop my big magnet into the oil and harvest all the micro metal particles, I would end up with about half of a US dime's worth. The second step after changing the oil (once again to conventional oil) is to do a compression test. So far, out of all the dozen I've done, all came out damn near exact from each other 1-2psi gradient. Now, drive on this new oil for another 1000 miles and change the oil. If you see a reduced amount of micro particles left on your magnetic drain plug (big magnet not used), then it is ready for synthetic. Usually the amount of micro metal pulled from the second oil change has barely enough metallic in it to smear across my thumb print. Anymore then that, I would continue to run conventional oil for another 1000 miles. Like always, drive it how you want after that first oil change, hard soft sideways upside down whatever floats your boat, 90% of the break-in was from the hard pulls in step 1.
Car: 95 240SX SE S14.5
New Plans: RB!
9200RPM Screamer SR22DET10.80@131mph 19psi /w Fully Built S14 Block /w Fully Built S13 Head T671.6 60ftRetired setup.
13.26@105mph 12psi /w S13 Blacktop2.00 60ftRetired setup.
Slowest Powerplant:Disaster SR22DET Paperweight, Built by JGY Customs
Modified by jjup_99 at 7:05 AM 6/19/2009
Modified by jjup_99 at 7:06 AM 6/19/2009
