fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun Jul 11, 2004 6:20 am
If you're really stuck, it might help to take another tire off and look at an assembled brake setup, and use that for reference. Basically though its pretty simple... the pads slide into the calipers with the help of these little clips/shims, then the whole thing goes over the rotor and bolted down with 2 bolts I think. If the pads dont fit on and over the rotor, you need to back the caliper piston out so you have room for the rotor. On the fronts you can just press them in with a c-clamp or something, but the rears need to be twisted in like a screw. There is a tool for this.
Good luck man!
