installing power windows?
MaKaVe1i
Car: racing, pc gaming
has anyone acomplished or knows how to install power windows on a non power windows 89' 240sx?
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
you basically just need to get all of the electronics including, motors, relays, fuses...
89240sx
Don't forget the windows and the regulators
D-UNIT
Car: a 91' S13 (15.014 @ 94.56mph NA) KA-T
One word SPAL. search for them. They sell universal kits that can convert almost any roll up window into a power window. The kit comes with everything needed for like $150 or so. Solid quailty. Fast too.
Soy
Car: '03 Mazdaspeed Protege #295
I can speak from experience on this one...
It's NOT worth it to put power windows in. My car had aftermarket power windows installed when i bought it, and I promptly removed them. Honestly, this is a 2-door car - why do you need power windows? I've found them to be slower and more inconvenient than having a handle, plus, adding power adds weight.. not much, but enough. Not to mention the wiring... oh lord... the wiring...
But, if you absolutely must have them, the aftermarket manual-to-power kits are your best bet, since otherwise you'd have to get your hands on a LOT of parts that can be pretty expensive.
James
D-UNIT
Here is the link. They have tons of cool innovative products. About the power window kits , they're super easy to install all you need is a drill gun. The only bad thing I can think of is that they are a little noisy. Highly acceptable if you never had power windows before. Super fast. My friend has been running them for over 3 years and no problems. It is almost to easy.
http://www.spal-usa.com --look under aftermarket parts. also check out their fans.
