Installing power door locks installation help...
trigger94587
Car: 90' 240sx Coupe
I Have a 90 240sx coupe and it has no power door locks and I want to install one because i want to put an aftermarket alarm system with keyless entry so wat parts do i need and how to install them... Thanks a lot!
ArcherV20
Car: 1995 240SX
If you put a system in, you might as well get someone from a shop to install it. It'll save you a lot of hassle and won't cost that much more.
AFIAK - you will need actuators to pop the locks. I haven't done this myself, but I'm not sure that there are too many parts involved. How are you at wiring things yourself? It can be a really tedious job.
trigger94587
Thanks for the help! I bring the car to the shop and let them intall the power door locks and alarm so everything is working properly now! =)
