12Ounce »
https://forums.nicoclub.com/12ounce-u52716.html
Sun Aug 12, 2007 4:20 am
I feel your pain!
I recently rebuilt a '93 K24e and know what you are going thru. I finally gave up on the rachet ring compressor ... they just don't build 'em like they use to.
Here's what finally worked for me. I went to a real (not Home Depot or Lowes) plumbers supply shop and bought a roll of good quality THICK WIDE metal pipe hanging strap ... the strap with all the holes in it. I cut a length that was ample to go around the piston plus a few inches. The ends are folded back, doubled over. A round slotted head screw (1/4" x 3"L), plus washers and nut ... gave me a rig that would really tightened up around the pistons and hold the rings deep in the grooves.
Have everything greased up good, line up everything carefully, then quickly pop the piston downward with a rubber hammer ... works bout every time! (I think that small bevel at the top of the cylinder prevents the head gasket being sheared into around the cylinder top. ... as well as a little lead-in for the rings.)
I threw away the store-bought rachet ring compressor and plan to use the pipe strap on all future rebuilds.
Modified by 12Ounce at 7:33 AM 8/12/2007
