installing panasonic stereo and stuck
crusader33x
Hello. I have spliced the original harness to connect with the panasonic harness but can't get any power. I tried searching and used the FAQ, attempting to splice into both the green/red wire (mentioned in the FAQ) and 1 post on here mentioned the pink wire, but the unit is not turning on. any suggestions?
does the antennae need to be plugged in (i dont have it at this moment) if so, which wire is the correct power? green/red or pink?
thanks
skylinekin
Car: 1990 Nissan 240SX Hatchback
you should purchase a test light...then you can check which wire is your 12v hot at all time source and check your 12v switched source by turning the key to the on position. I cant remember which colors were which off the top of my head otherwise id tell you.
driftneil
Car: A pile of cars.
The antenna has to be pluged in, its a ground
