Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Wed Jul 29, 2009 4:51 am
I'm not extremely familiar with the Bose setup, but I though that the factory speaker and amplifier for the front doors were one unit, thus requiring you to remove the speaker and amp as one?
Anyhow, let me try to explain what I was talking about before...
The factory Bose head unit does not have an internal amplifier, which means it is not powerful enough to power speakers alone. The Bose head unit will have standard speaker outputs (Front/Right, Front/Left, Rear/Right, Rear/Left) just like every other head unit, with one exception. Those outputs will only output a low-level signal, meaning they output probably a maximum of 2V or 3V.
That low-level signal is then sent to each respective amplifier, which then, depending on the amplifier, will amplify the signal. So let's say (hypothetically) that each factory Bose speaker has a voltage gain of 10 and the factory Bose head unit has a low-level signal output of 3V. Each amplifier will output a 30V signal to the speakers (10 x 3).
Now, when you pull out the factory head unit and replace it with a new head unit with an internal MOSFET amplifier, you are now sending a high-level signal (an already amplified signal) to each respective amplifier. So say your new head unit sends 10V per channel already to each amplifier which have a voltage gain of 10, you are now trying to send 100V to the speakers. Now the speakers may be able to handle the power, but the factory amplifier cannot. Those amplifiers are definitely not spec'd to handle and output of 100V (let alone an input of 10V).
So when you turn up your volume, thus increasing the current, you are in effect pushing the amplifier to the limits, and that is probably causing the static noise.
Now, I could be completely wrong and your head unit may have pre-amp outputs which are connected to those amplifiers, but I have a feeling that they are not. Did you wire your head unit or did you have it done by somebody?
My solution:
When you pull the amplifier out of the door, you want to take the wires that come from the head unit (the harness going into each amplifier) for that speaker, and patch it to the amplifier output for that speaker.
I don't know, I may be nuts and wrong about everything, but from what you've written this sounds like your problem.
