celica3sgte94 wrote:ITS REALLY EASY JUST LIFT UP THE MOTOR AS MUCH AS U CAN WITH A CRAINE AND JUST UNBOLT IT I DONT KNOW ABOUT THE TRANSMISSION SINCE I NEVER TRIED BUT SHOULDNT BE HARD AT ALL
Simply lifting the motor up will lift the front end of the car. You have to remove the motor mounts nuts before lifting the engine up off the mounts.
Swapping the mounts is easier when the engine is out of the bay. Other wise you need: 1Remove nuts off of the top and bottom of the mounts. 2. Loosen and lower the crossmember from the frame 3. remove the mounts.
