shorside wrote:well heres what i did yes it takes 6.5 speakers but you cant put the same size in the hole unless you put i a spacer if you dont it wont fint i tryed unless you realy wanna do some cuting what i did was drimle out the old spaker and used it as a spacer for the replacement that is what i did i also taked with a shop nere me thay told me that thay would make a spacer for the new speaker so i just cheated and used the old speaker as a spacer.
I did the same thing, but I put foam between the new speakers and the spacer and attached the new speaker with the spacer using zip ties.
