navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Mon Dec 20, 2004 5:00 pm
yellow is antenna and cannot be connected to a power source, ground or other. must be bare. red goes to positive on the battery or acc. like you said, and if you tapped the A/C, that may be why. you would be better off going from the key switch or somthing that turnes on when the car is running, fuel pump is just one thing that comes to mind but you would be better off attaching it to somthing else other then the pump.
