I have searched everywhere and cant find enough info. Help is appreciated.
I have a 93 240 ka24det.
Im in the middle of wiring up MS1 v3 and need to locate the IAT sensor. The FSM says its in the air cleaner box but ive looked and there is none. I have a ECU pinout diagram and says it should be pin# 26 (I think. dont have the paperwork in front of me) But I also have a full wiring diagram for my car and there is no pin# 26.
Also I need to hoop up 4 wires from the Stepper IAC (could not find any info on this at all) but dont know the location or pin#'s to pull from. Would this be another name for AIV cause i located that.
Last one is the Fast Idle Solenoid. I need to tap a wire that comes out of the relay box for this.
You can find a link for the harness here
http://www.megamanual.com/. Click on "Sensors and Wiring" on the left side, then the "V3 Mainboard" link near the top of the page.
