Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Wed Jul 21, 2004 1:59 pm
Hey, the 240 has negative style locks, where when the lock wire is pulsed with a grounded signal it locks, unlocking is the same, only using a different wire. This action activates one side of a coil in the factory door control Assembly. This system works the same on both the S13, and S14. Although, I have seen some of the 240sx models in the early years that had the same system as the 300zx. These required a relay that could open the circuit or pulse the same wire for locking and unlocking. I'm not sure what the determining factor for these models is but to test it. Try testing the wire when operating the locks. If the multi-meter read continuity to ground when you push the lock lever in one direction, and displays 000 when moved in the other direction, then it is a one wire system. If you cut the wire with a pair of Diagonal side cutters the doors should unlock. However, most of the 240s have the Negative style! Also some keyless systems require a couple of SPDT relays, due to very small current onboard circuits of 500ma or less for the locking/unlocking outputs. In either case good luck.
