Installing ICC / Cruise Control into Fuga Y50
kenke
Car: 2006 Nissan Fuga 350GT
Hey,
I recently upgraded my Fuga's multimedia system to an English system with lots of lil jazzed up bits but seeing as I'm in the auto spirit, I was wondering if there was any way to add Cruise Control to the car?
Any help is appreciated!
Ilya
I would start with checking to see if your car is pre-wired for ICC. If it is, then you just need to find the components. If it's not, then you'd need the harnesses, etc. for that. You can get the wiring locations/schematics from the FSMs on this site!
cbird805
Car: 2003 Infiniti M45
1995 Infiniti Q45 Base
(prev) 1994 Infiniti Q45 Base
You're better off without the ICC system. The sensor was prone to water damage due to people driving through water. Also, it had a rather obtrusive lane departure warning system, and prone to false detection of vehicles. I'm sure there are quite a few owners that wish they had standard cruise control instead. Earlier system disabled cruise control if any ICC module wasn't working. I think the later years M45 had a bypass to be able to use standard cruise control.
