wakotow wrote:Oil feed at block M12X1.5 its m12 x1.25 on the blockOil feed at turbo M12X1.5 (HX35)Water feed at block is M16X1.5 its m14x1.5Oil return at block 3/4 bspt
Raw Brokerage has the 3/4bsp to dash fitting if you want to run braided lines. Otherwise you just need a new piece of hose using the same oil return tube-thing from stock turbo.
For the feed line, I just bought -4 an line and two m12x.5 to -4an fittings from summit and the DIY hose ends, I didn't run a restictor at al and it's workig so far.
