ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Wed Apr 09, 2008 1:21 pm
Well, yeah... They hold the head and gasket in the EXACT location. The dowel pins have absolutely no play between the head and block side to side, where as the head studs or head bolts do have a little slack in their holes. Putting the head on without the dowels can allow the head to shift in different directions up to 2-3mm during installation. If you do manage to put the head on straight, I don't ever see it moving after torquing down. If you are already without a dowel or two, and the head was aligned straight during installation, then I wouldn't worry about it too much. If you have no dowels prior to installation, I would get some due to the nature of what CAN go wrong without them. They are cheap anyway. It's the little things that sometimes make or break you. I am pretty anal on my assembly processes, so if I personally found out I forgot one of the two dowels, I'd tear the motor back down .
