help;
just put head back on car (bought it in pieces).
manual says to match up chain with marks on sprcket. but i don't know where bottom sprocket is lined up on chain. i do not want to pull cover.
do i just set piston 1 to TDC and timing to 0 deg.
then put cam sprocket with pin at top and not worry about chain marks?
also
my cam sprocket clicks to a stop a few degrees to right of the top due to pressure on cams is this close enough
how does setting timing with distributor affect this timing or does it only affect when plug fires in relation to piston position.
thanks
