Installing Head gasket ca18det
Ca18det240sxchk
Car: nissan 240sx swapped ca18det
Please tell me what EXACTLY i need to do and take out to install head gasket,,, detailed instructions.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
hmm where to start. pull the valve covers, timing cover etc.
set engine to tdc.
drain radiator
unhook hoses. remove timing belt
pull off turbo/manifold
remove intake manifold brace
remove the intake manifold or leave it on the head, up to you
undo the headbolts pull off the head
theres more to it then that
not a first time project.
Ca18det240sxchk
so i should definitley have some1 that knows what there doing with me than huh? good learning experience....
RICERMAN
The best advice I can offer is the get a service manual and READ it several times about doing this repair. Its not rocket science but you need to know exzactly what you need to do before you start removing parts.
rotorimp
Car: 02 Xterra, 60 IH Metro
Yes ---find someone that has done it before--You will also need a Good Torque wrench to torque the head bolts back on.
RICERMAN
rotorimp wrote:Yes ---find someone that has done it before--You will also need a Good Torque wrench to torque the head bolts back on.
True. I have to admire an inexperienced mechanic whos not afraid to tackle a big job......thats what it takes Most young males today dont care to learn even how to open the hood to check their oil.
rotorimp
I saw a beautiful Porsche 924 turbo When I was 16. I started reading everything I could get my hands on and haven't stopped working on cars since! I can rebuild any engine and wire a motor into a car that it was never meant to go into. Point is--Due Diligence and the drive to do and there is nothing you can't do!
RICERMAN
Cool. If I have any questions about the 95 engine Im swaping to a 94 I will be asking for your advice.
nizfanatic
If the gasket has been customized, check it for good fit around all the head studs. The fit should be tight. It is best to remove all the studs and lay the gasket on the deck first then replace the studs. If there is a bit of a bind around any of the head stud holes just relieve that location a bit with a deburring tool or a smooth round file. If this is necessary make sure you clean the burr that remains. Use a fine sandpaper (100grit) on a sanding block. that was i did for mine.
MaximA32
The CA isn't exactly a difficult motor to work on. It's a whole lot simpler than working on a transverse V motor.
capowered240
Car: 90 240sx
Here is a pretty good removing and replacing illistration of the head gasket. hope this helps.
http://www.davidrawlinson.org.....html
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
The CA is immensely easier to work on than the SR20!! OMG, what a pain the SR20 is.
