Installing harness connectors, uclips. Tips?
es.biggs
Car: 1990 300ZX 5sp NA
So the injector and IACV, etc. connectors were very difficult to remove before I pulled my engine. Now I have to re-attach everything. Whats the best way to do it? The metal u-clips are the part I'm more concerned with. Seems impossible to attach them to the injector connectors way below the plenum. Are you supposed to put the u-clips on the harness connectors before you push them on or after?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Keep the clips on the connectors and push them into the mating sensors/injectors. They should click once attached.
robomatic12
Car: 1990 300ZX TT
Clips go on connectors before you push them on. I find it's easiest to put two flat head screw drivers inside the connector so that when you slide the clip on it doesn't snap into the middle and not click all the way in. If that makes sense at all
es.biggs
It does! Thanks guys. I see the light now lol my life just got easier.
