Natedogg1701 »
https://forums.nicoclub.com/natedogg1701-u145796.html
Mon Nov 23, 2009 4:22 am
you said the kit has an hid low beam and a halogen high beam? if this is like the kits ive seen it has the 2 lamps right next to eachother correct? if it is then it purposely doesnt allow you to turn both of them on, the heat generated by these 2 lamps on at the same time while they are right next to eachother will burn them out, i ordered one of these kits for a buddy and we wired it so both would come on at the same time when he hit his high beams and they burnt out very quickly. also there is nothing wrong with your wiring, if you had a normal 9003/h4/hb2 halogen bulb in there it is a dual element bulb, when you hit the highbeams it turns off one element and turns on the other one, the element used for the high beams is set back further in the halogen lamp so it reflects higher up. if i were you id either just use the hid low beams, because an hid is 3x brighter than halogen, or like body80 is talking about, get a bixenon kit, it uses telescopic bulbs, so when you switch between high and low beam, the hid stays on it just sucks the bulb in to the housing via a magnet on the back of the bulb, causing the light to be reflected differently. i have a bixenon kit and i love it, and i need one to pass inspection. lol
