Are u sure about those colors? Hooked it up and gauges don't light. I'm using greddy so simple 4 wire. Blacks all ground. Reds I connected to white wire, and the white and oranges I connected to blue. Boost gauge is on all the time even when car is off and it is only connected to blue. So blue wire is acting like constant.krash wrote:You could use the ignition harness. Coming straight out of the ignition the White wire is a +12v constant, and the Blue wire is the accessory wire.
That harness goes from the ignition to a pigtail under the steering wheel (above the pedals), where it changes colors and goes to different places in the car. So if you're going to cut in from after the pigtail, make sure you pay attention to the colors.
