installing fogs using only car battery. need some help.
Heels1010
looking into buying these fogs on ebay. I like the fact it only attatches to the attery for power. seems like the install would be easier then wiring my 2.5 entirely for fogs.
http://cgi.ebay.com/ebaymotors...A1171
Couple of questions???????I would have no problem wiring the fogs to the battery, but how would u run the wires to the switch inside? also how would u install the switch?
can the battery withstand HID fireup without overpowering anything?
I know some of you think the fogs are skeptical about quality but he has good feedback and this is the only system seeming easier for 2.5 ers with no pre-wiring required. What you guys think?
alticoupe3.5
Car: NISSAN ALTIMA COUPE
you would have to run the wires through the firewall. by the break pedal..behind it, there are a whole bunch of wires that are wrapped together that all go to the battery. when i installed my led's i had to run them through the firewall and put the switch right next to my traction control switch.....it requires some cutting and a little force to be able to get through the firewall also.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Good Luck!!!!
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
alticoupe3.5 wrote:you would have to run the wires through the firewall. by the break pedal..behind it, there are a whole bunch of wires that are wrapped together that all go to the battery. when i installed my led's i had to run them through the firewall and put the switch right next to my traction control switch.....it requires some cutting and a little force to be able to get through the firewall also.
NO YOU DONT AND DANGERIS READ MY WRITEUP
lol in it it says about how YOU CAN BYPASS THE FIREWALL so hahaha i found a secret now read lol
ESP
Car: 2008 SexyBlack A/C
Matt, I wired my LEDs by going alongside the door just like you did...eight months ago!While it functionally works just peachy, it bothers the piss outta me because it just looks so unfinished. I figured that by using a black wire I wouldn't even know it's there...wrong! Every time I open my door it bothers me because I just know it's there! In the next week or two I'm going to put in a new grommet in the firewall for the express purpose of throwing my own wires through it...
PHENOMenalVinyl
hahaha y didnt u ever tell us lol its so much easier i dont mind it i taped both wires that go through there so its not bad they blend in pretty well
DaCoupe
Car: 2009 Nissan Altima Coupe 6MT, 2006 Ninja ZX-6 636, 2011 Mustang GT 5.0
there was a thread about these fogs before, not a good buy, cheap and not DOT approved, go with OEM instead:
http://cgi.ebay.ca/NISSAN-ALTI...l1116
khisanthax
will the coupe fog lights work with the sedan or is it different?
Coupeguy23
Car: 2006 G35 coupe sport
khisanthax wrote:will the coupe fog lights work with the sedan or is it different?
no there not the same i learned that the hard way sedan are a lil bit bigger then the coupes
