Installing flywheel, clutch - where does rear plate go?
es.biggs
Car: 1990 300ZX 5sp NA
Where does the rear plate/dust cover go? Between the flywheel and the block? Just want to make sure, because I can't remember where it came from...it's been such a long time since I pulled the transmission down :/
By this diagram it looks like it bolts directly up to the block. It's drawn up there with the flywheel not even in the picture.
http://www.courtesyparts.com/300zx-part ... 4_887.html
Also, the rubber seal that is stuck to the bottom plate came halfway off...should I use rtv to seal it or use some type of edhesive? I know it gets really hot in there, so it would have to be something high-temp resistant
redneck zx
Car: 1991 300zx TT
plate gose between the flyweel and block put in on before the flywheel
and as for the seal i guess you can rtv it on i drove my car for 6 mouths wihtout the plate at all but id sugest not doing that lol
