TheClevelandSound wrote:lol well i think its cool and thats all that matters...
Now you've got the idea! Be aware that everyone is going to give you their opinion, but only yours matters when you're modding your own car. I'm like almost everyone else in this forum - I wouldn't install underglow neon lighting on my Versa, but I commend you for doing what you want regardless of what other people think. It seems that most of the people in this thread would rather bash your idea than answer your question, so let me take a shot at it. As far as installation is concerned: I agree with everyone else in this thread when they say that you need to mount them in a fashion that you don't see the lights themselves, just the glow from them. Be sure to conceal them behind any lip or body line under the vehicle that will allow them to be hidden to the eye from the side of the car. The actual mounting can be done many ways, including L-brackets from a hardware store, zip-ties, bailing twine, etc, but chances are that the kit will ship with some sort of brackets that should be suffecient. Just use short self tapping sheet metal screws or non self tapping and drill a pilot hole to attach the brackets. As far as wiring: I'm not sure what's going to be included in your kit, but the basic procedure is this: You need to run a relay, which is best described as a remotely located switch (a relay may or may not be included with your kit). The relay will allow you to tap directly into power from the battery, and then run wires from the relay to the neon lighting. Then, you can mount a switch inside the car and connect it to the relay. When you flip the switch in the car, it'll activate the relay which will send power directly from the battery to the lights. You can tap into a wire in the fuse panel inside the car to draw power for the switch that activates the relay, and I would suggest drawing it from a fuse that turns off with your ignition (such as your power outlet) so that you don't accidentally leave the lights on and kill your battery. Your kit should hopefully come with wiring instructions, but if it doesn't, a relay will have basic instructions on the package or you can do a google search. Hope that helps!
