Darius »
https://forums.nicoclub.com/darius-u5470.html
Fri Mar 19, 2010 7:13 am
I'll stress torquing the cam down too. Tighten the cam caps down as evenly on each cap as you can to keep them perpendicular to the camshaft and the opposite mating surface. And only do a couple turns at a time.
I remember not following the FSM torquing order exactly because some would be tight and others super loose. I just turned whatever was loosest a couple times and tried to keep the caps as even as possible. Do the final torque in the FSM sequence. Don't rush. It took me about 15 minutes to get one cam into place and torqued down.
Another thing you should do is back the cylinders down from TDC (CCW about 20*) before you install the cam. The cam is difficult to install at the perfect angle and can result in piston to valve interference while you torque the cam down as evidenced by my valve breakage experience. Once it is torqued down, rotate the crank forwards to TDC and the same with the camshaft.
Modified by Darius at 12:18 PM 3/19/2010
