installing everything on next friday.
tvmendoza
Car: 240sx 95
Hello, if my wg arrives on next week i will install i will begin the work on friday. I just have a few questions before i begin.
1.- Do i need to lift the motor or how hard is to put out the oil pan, is there any motor mounts??2.- Where should get vacuum lines(for wastegate, and bov).3.- Where am i going to plug the oil sending unit.
On 2 and 3 if you have pictures that will be great.
I hope everything goes find and i will be a kat the 10/2/05 Thanks in advanceTona
tvmendoza
Car: 240sx 95
sorry i miss the year my car is a 95 240sx. I am not sure if you need that but just making sure. ka24de of course.
Florida240sx
For my oil pan removal I did this.1.Drain the oil2.brake booster line and purple plug disconnect3.remove fornt sway bar4.get block of wood5.jack up front of car and have it on jackstands6.remove all oil pan bolts and put in a bag7. have a friend slowly jack up under your powersteering pump/or A/C forget which it was.(on the bottom)put block of wood in between for greater surface area to push on8.Slowly jack up motor until you can remove oil pan(make sure theres isn't anything else being tugged on)Or you can drop your crossmemeber but I did it the way listed above. After you remove mani and exhaust do this. Anyone else have tips or areas to correct me on?
tvmendoza
Car: 240sx 95
Thanks for your help florida, it does not look that hard.
