installing dvd and nav unit
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
bluepitbull04
Car: 2006 INFINTI G35 COUPE 6MT
when installing a dvd unit u run the e-brake wire and speed sensor wire to ground right. and yes i look in the forum for the answer couldnt find the answer
joe603
Car: 2014 Durango R/T
Hang tight...someone will hopefully know.
C-Kwik
The e-brake signal just needs to be grounded, yes. Not so sure about the speed signal. I'd imagine it detects the pulsing from the vehicle's speed sensor though so simply leaving it disconnected may work. You might try hooking everything else up and then seeing if it works this way. If that doesn't work, of course, using a ground signal might.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
C-kwik is right. Speed sensor wire just needs cut, not grounded. Here is step by step directions on how to bypass it:
http://www.nicoclub.com/articles.php?id=331450
C-Kwik
Maybe I'm misunderstanding the OP, but I had figured he was referring to how to install an aftermarket headunit that has a e-brake and speed sensor hookup. Considering his profiles says he has a 06 G35, I don't think that article applies to him.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
I didn't realize the article was for 08's. But regardless, the same wiring would apply. Ground the brake sensor, cut the speed sensor.
bluepitbull04
i would like to thank everyone for their help i will try running the e-brake to ground and just leaving the speed sensor alone i just have to for the local audio shop to get my hardness in and for my friend to give his dash kit which he is suppose to be taking out next week
C-Kwik
EZcheese15 wrote:I didn't realize the article was for 08's. But regardless, the same wiring would apply. Ground the brake sensor, cut the speed sensor.
The 06 doesn't have an aux video input AFAIK. If he had navi in his G already, he would need an aux input switching device like avelectronic or tvandnav2go makes. Such a device simply splices into the wiring between the video screen and the nav unit which passes through the signal when switched off, but adds the aux video signal when switched on.
But in his case, it sounds like he is simply adding a DVD/NAV headunit and needs to know how to wire the e-brake and speed sensor safety signal from the aftermarket headunit to bypass its safety lockouts. If this is indeed the case, there would be no need to cut any of the factory wiring.
bluepitbull04 wrote:i just have to for the local audio shop to get my hardness in
LOL...
If you are indeed putting in an aftermarket unit, please do keep us posted, including the unit you are using and what the solution was so we can have it here for future reference. Thanks and good luck!
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
If it is aftermarket say what one it is. They do manage to have different ways to make it work.
smockers83
Car: 2006 G35 Coupe
Depending on the unit, you can rewrite the software to bypass it. Then if you ever get into legal issues, you can revert the software back to it's original form and say you had it hooked up the whole time.
C-Kwik
A manufacturer's inclusion of the safety mechanisms are likely to provide them with a legal safety net should someone inevitably do something stupid like drive off a cliff while watching a movie in their car. By providing the feature and including its installation in the instructions, they basically cover their butts in case someone tries to argue that no safety lockout feature was made available. If the owner or installer bypasses this portion of the install, there legal liability is shifted from them.
From a perspective of a driver, the only issue that would come into play is if an officer actually witnessed you displaying a video source on the display while driving. There is no law that says there must be a safety lockout on such a device to my knowledge. Or in other words, an officer wouldn't cite you for not having the lockout installed correctly. They would cite you for watching a movie while driving.
bluepitbull04
ITS PIONEER'S AVIC-F90BT MODEL
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I'll look into what you have to do with that one. Pioneer is the bane of installers as far as bypasses go. I had to do a software update and add a wire to the harness get my Z1 to work.
smockers83
Car: 2006 G35 Coupe
C-Kwik wrote:A manufacturer's inclusion of the safety mechanisms are likely to provide them with a legal safety net should someone inevitably do something stupid like drive off a cliff while watching a movie in their car. By providing the feature and including its installation in the instructions, they basically cover their butts in case someone tries to argue that no safety lockout feature was made available. If the owner or installer bypasses this portion of the install, there legal liability is shifted from them.
Right...being cited for watching a movie while moving is a legal issue. You reinstall the original code, contest the ticket saying the officer couldn't have seen a movie because it doesn't work.
bluepitbull04 wrote:ITS PIONEER'S AVIC-F90BT MODEL
Nice choice. That's the one I'm going to be getting. You should put up some pics when the install is done. Go to avic411.com and under their forums, people have rewrote some of the software to customize it, including a software bypass.
bluepitbull04
thanks smocker83 i didnt do the software bypass (which included rewriting the software) i have a mac plus the hardware bypass (which included moving the mute wire to a different pin and grounding it out and grounding out the e-brake wire) seemed a little easier i all work just have it install the mic for the phone opion thank you all all of u helped me in some big or small
rpm240sx
Car: 2004 Infiniti G35 Coupe
This may or may not help you out. I have a Kenwood DDX514 and wanted the dvd player to function when in motion. I found a guy with an online ebay store that makes bypass's that are radio specific. I'm sure there may be an easier less costly way but this worked just fine for me. They don't cost that much...this is their ebay name (specialtyelectronics) Good luck!
bluepitbull04
thanks but i already did the bypass myself it really wasn't that hard popped the wire out n put it in a new location and grounded it and e-brake wire out but the software is a little bit better cause you and change icons i.e the red triangle u can actually make it a car
Return to “G35 and G37 Interior, Exterior and Audio”
