Installing Components in the pathfinder - Taking out BOSE system! NEED HELP!
eskay247
Modified by stevek247 at 3:19 PM 3/24/2009
kevin1488
Its just easier to rewire everything to your deck/amp which ever you are using did hundreds of bose systems in my days. any questions you can call 360-770-7774 Kevin
ganesh21
Car: '12 Honda Pilot
what i did was trim the wire at each door.
then i hook up a speaker(old one for testing) to each door. what i did was test speaker connection on the harness for the front door. then i just run 12g to the amp.
for the rear door. i did the same(hook up an old speaker for test) on each door.i took off the the internal amp in the rear left panel. i then match the color of the wire at rear door.
No need to run wire through the grommet in the door,
Modified by ganesh21 at 12:41 PM 1/30/2008
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
ganesh, you used the factory wiring if I'm understanding correctly?Sounds a bit easier. . the wiring is actually what keeps me away from it
bmlawless
Car: 1999 Infinity QX4
Did you replace more than just the speakers? Take a look at the new thread I just started along the same lines.
