jmann wrote:They must have stated this for some arbitrary liability reason. If the anchors are sufficient to restrain seats on the left or right, then it only stands to reason that the inside ones can restrain a seat mounted in the middle.
It's easy to think that, but you have to be careful sometimes. I don't think they stated for arbitrary legal/liability reasons; I believe that it was done deliberately, and that LATCH system in the EX was designed specifically for use in the outboard positions.
See the following links:
http://www.car-safety.org/latch.html
http://www.car-seat.org/showthread.php?t=33718
Will the LATCH anchors hooked to a center mounted carseat hold up in the event of an accident? Probably. (I'd be much more concerned if 2 carseats shared one anchor.) However, I don't think the LATCH was tested in the center mounted carseat configuration. I wouldn't want to be the one to find out how the anchors fare in an accident.
BTW, LATCH was designed for convenience; it makes it easier for the average user to get a tight and proper installation of the carseat when compared to a seatbelt installation. Since the carseats in my vehicles are removed very infrequently, I ignore the LATCH and spend the extra time and effort installing them with the seatbelt. If I had to swap carseats between vehicles on a semi-regular basis, I'd probably use the LATCH.
