installing cd player into my 91 240
spano
Car: 1991 Nissan 240SX LE
i got the car a few days ago, and it came with a tape player so i want to replace it with my cd player but want to know what the easiest way to get the tape player out is, the wiring is no problem i just dont want to be taking apart the whole car to get the tape player out if i don't have to
onosqv
Car: '92 240sx Vert
Been a while, but I don't think you need any special tools.
Pop the radio bezel trim by hand (usually area around shifter will pop up pretty easily).
Lay that aside & take out the 4 bolts holding in the player & din pocket.
You should know what to do from there.
Orzel
For my 95, I just popped the plastic around the shifter out, then the plastic around the air vents out (no screws hold these two pieces), then I just undid the screws holding the Tape Deck, installed my CD Deck, and put it all back together.
ca240sx
Car: 1995 240sx
Its just that easy, take off the bezeling and unscrew, if you keep that bottom din tray you can re-attach it with your new stereo, there will be a very small gap. Also if you're getting a cd player with a plug for your antenna you're going to have to buy the adapter to make the connection (thats if you want to listen to the radio) I think its like 10 bucks, I got mine at best buy.
