Installing cas and motor made sound I didn't like
schanne
Car: 93 Hatch-Sr20
Took my CAS out to check the dots and see if they were lined up. They were a litle off to the right. So I installed just like the FSM says but with the VC on. It slided right in with no problem, but on start up motor would turn and die with a metal to metal sound right before dying. Wasn't horrible, but.... What did I do wrong here?pulley was set to second mark from the left
Time for rebuild?
schanne
Car: 93 Hatch-Sr20
Help?
bruinbear714
schanne wrote:Help?
Was your engine working before the CAS was re-aligned?
If it was, then you will have to realign the CAS again and do it right this time. If it wasn't working, then something else is the problem.
schanne
Car: 93 Hatch-Sr20
It did work before. Just making sure I didn't cause devistation.
