nissan_s14 »
https://forums.nicoclub.com/nissan-s14-u3122.html
Wed Aug 06, 2003 5:25 pm
Hey all, I am re-installing the camshafts and adding Tomei Rocker arm stoppers to the head of my SR20DET s13 blacktop. When I tested the hydraulic lifters before adding the camshafts, they had more than 1mm play. As a result, I followed the FSM and removed all the air using a tupperware full of oil. The lifters now do not move at all (at least not with my bare hands). I positioned the exhaust (left) camshaft at the 12 o clock position, but it will not "seat" fully. The camshaft brackets are positioned too high and wont seat completely over the bolt holes (bolts will barely thread in). Same goes for the intake (right) camshaft...sits too high. What do I do? Do i position the cam brackets and then just follow the FSM in the bolting sequence and torque values, allowing the bolts to "seat" the camshaft? Do I rotate the camshaft in a different position besides the 12oclock and then bolt? Are my hydraulic lifters just too stiff? Should I try to get some air back in em?
sorry for the long post!
edit: looked at past posts and the sr.hyrbids install page, but couldnt answer my question
