fxjackso »
https://forums.nicoclub.com/fxjackso-u250.html
Wed Oct 16, 2002 12:51 pm
I would agree that this is one of the easier DIY jobs. Energy Suspension makes 28 and 20 mm sway bar bushings for front and rear. You can also use washers to tighten up the bars per Q45tech's advice.
HOWEVER, I caution you that, if your active suspension is working correctly, your spring rates are very soft compared with the standard Q. At low speed you have a LOT more suspension travel than a standard. Therefore, the poly sway bar bushings will make noise. Grease, refinish the bars, get graphite impregnated bushings-the noise will return! Second, again because of the soft springs and ride, coupled with the newly stiffened bars, the car will follow bumps and irregularities in the road surface, and may wander when the road has a high crown. But you will love the cornering.
That's the price of the cushy ride. Don't get me wrong, I miss my active Q and would love to find another. I just couldn't say no to my new standard car due to its great overall condition.
