float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Jul 27, 2006 5:51 pm
Are you trying to plug the middle plug into the black box that is bolted directly to the throttle body, or to the plug that is attached via a set of wires that comes out of that black box?
One of the other wires is for the Engine temperature sensor and may or maynot plug into the harness. The other is the Intake Air temperature sensor plug. The stock setup doesn't have an IAT, you'll have to get one from SDS, or one from a GM, I don't remember the part number off the top of my head right now. The IAT sensor should be installed after the intercooler, befor the throttle body. Don't put it in the intake manifold, as you'll have problems with heat soak. Mine is DIRECTLY infront of the TB, as close as I could get it.
