Installing an Amp in my '04 Altima
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Chazz718
Car: 2004 Nissan Altima
I'm attempting to install an amplifier in my Altima. However, I can't find a place to run the power wire through. Do I need to drill a hole? If so, where is a safe place without causing any problems?
bigboy9295
Car: 2002 Nissan Altima
You will need to drill a hole. The best place to drill is in the drivers side wheel well. If you pull off your drivers side tire, remove the plastic shroud toward the rear of the wheel well, you will see where your hood release cable runs. Just drill your hole around your hood release cable because there is no obstacles around it. Here's a link with pictures....
http://www.cardomain.com/ride/604197/4
Return to “3rd Generation Altima Sedan (2002-2006)”
