IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Nov 13, 2003 12:16 pm
actually, flex a lite makes a temperature switch that i installed in my uncles cherokee. i removed the mechanical fan and ac fan, installed dual flex-a-lites, ran a relay to energize the system when the ignition is on, and the temperature kit includes a sensor on copper capillary tubing that you insert into the coolant flow. the capillary tubing goes to a microswitch assembly that has an adjustable on/off point.
i placed it on the hot side of the radiator so as long as the engine is under load, the fans are running.
