installing air horns in the Q
qship96
Car: 1996 Infiniti Q45
I am inatalling a Fiamm dual trumpet air horn-can I wire the air compressor {15 amp} directly to the q horn wire,or will a relay system need to be installed? FSM shows the circuit to be a 15 amp if I am reading it correctly-anyone try this setup yet? stock horn,while weak when new,is getting weaker with old age!
Direct plug-in, no relay required.
Mine's been that way for 2 years, not a problem.
PoorManQ45
Greg: DOn't want to do that. Too high of a current draw for such tiny wire.
I recommend using a relay connected to the Q's horn wiring.
*edit* I was thinking about installing a train style air horn on my Q. That ought to be good for giving th eold guy infront of me a heart attack
metaverse3
unless you can verify your horn has a higher amperage relay, i would wire a relay..
On my maxima, I have the +12v on the air horns wired directly to the battery fused. I use the car's horn wire trigger a relay which supplies ground to the air horns to complete the circuit.
When I had it wired directly, it kept blowing fuses. I found out the horn relay was a low amperage relay causing a circuit overload.
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
i have 2 sets of air horns wired directly for years now w/no problemi set up frontand one set in rear of engine compartment
qship96
james,why 2 sets? what do the ones in rear of compartment do?
Apparently you guys missed the part of his post that shows the FSM designating it as a 15A circuit.
Like I said, it will be fine. I have had mine wired as such for 2+ years with no consequence.
The Q desperately needed a serious horn, and the 139dB unit I installed does the job.
The convertible and Pathfinder will be getting one soon as well. Search "139bB" on ebay, they're self-contained and run about $40.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Where are you guys getting your units??? I want to do that sometime, as when i honk my horn people laugh at me
PoorManQ45
AZhitman wrote:Like I said, it will be fine. I have had mine wired as such for 2+ years with no consequence.
You don't have an air horn do you? Most likely you have an electronic compression driver that takes about 12~24 watts. = 1~2A
ALL air horns require a compressed air source. This is usually a small compressor with a low volume storage tank. If the Horn is indeed rated at a continuos 15a then it definately WILL blow a 15A fuse sinse ALL motors draw atleast twice of their RMS power upon startup.
Sinse you're already in the engine compartment why not just connect a relay with power directly from the battery? Not too much work and you're SURE that there won't be a problem.
Greg, how much was your horn?
Anything beats the weakling beep of the Q.
Jesda, Wes and PMQ:
The convertible and Pathfinder will be getting one soon as well. Search "139dB" on ebay, they're self-contained and run about $40.
Yes, it's an air horn with a small self-contained compressor. No, it's never blown a fuse, and yea, it's loud as all hell.
elwesso
2007 BMW M Coupe
What does it sound like.. is it just a really loud horn, high or low pitched...?
Um, sounds like an air horn.
Not low like a foghorn, not high like a stock Q, in between.
Call me and I'll put the phone up to the horn for ya.
PoorManQ45
AZhitman wrote:Jesda, Wes and PMQ:
Oh, sorry for doubting you Greg. I just like to play things safe, you know? If you use a 20amp relay you can run quite a few horns off of it.
elwesso
2007 BMW M Coupe
As long as its screaming "I own you" or "get outta my way" or "your flaming slow" thats perfect...
When I went down to the dominican the busses has multiple horns... The regular horn was honked at anything that came within 10 feet of the bus, and the other one was used for everything else. Our bus driver said, the first one was used to denote "be careful", and the other one was "you *insert adjective* idiot get the *insert adverb* out of my way"
Well, this one says, "Get the *** AWAY from my car!!!!"
Keep in mind the alarm uses the horn as well.
Q451990
Hitman... does this look like the one?
Auction Link
Heath
Yep.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
i've seen these on ebay, and plan on getting one (thanks for your previous heads up greg!). i used to think about matching the perferct horn tone to the Q, but think about it, the only time you use your horn is to get someones attention. and,,,if some a-hole is ready to slam into my Q, i want the loudest, "attention getter" screaming from under my hood!!!!!! get the air horn!
zinkie13
Car: 1992 Lexus SC300 Single Turbo
At some point I am just going to get an air compressor and a horn from a semi. Then i'll really be able to make some noise
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yeah, I want one of those three foot chrome trumpets on my front fender.
BobE
Car: 95 Q45 98K
In '73 I bought a 72 Olds Cutlass, it had the best (LOUDEST) horns of any car I've ever owned. They looked like any other car horns, someone told me they were 'noise pollution' horns. Never found any since that came close. First time I honked the Q I had a flashback to my 383 roadrunner. meep meep
nuQ
do a search on ebay for 72 cutlass horns!!!!!
Haha, had the same ones in my 68 GranSport (Buick). Loud as hell.
Not as loud as these, though.
p.s. 68-72 GM A-body cars: Mmmmmmmm
Jason B
Car: Infiniti Q45
I've done this to my 4Runner. Used the stock horn wires and fuse. I've had this in for 3 years and what a difference.
Pepboys.
Click to hear the factory horns first and the air horns second.
http://www.toyotaoffroad.net/j...n.wav
PoorManQ45
I like that the airhorn is louder, but it still sounds a bit girly IMO.
I would want something that sounded like a train horn.
SFBayQ45
Car: cars
elwesso wrote:As long as its screaming "I own you" or "get outta my way" or "your flaming slow" thats perfect...
Hitman - Do you have any pictures of how and where you hooked up the horn?
Wes - Could you get one and do a write up on it to share with the rest of the us?
PoorManQ45
heRE, I'll do a write up.
Cut wires going into OEM horn. Cut back insulation enough to splice together with another wire. Then connect wire supplied with horn to OEM wires. Polarity doesn't matter, so don't worry about which is positive and negative.
elwesso
2007 BMW M Coupe
Thank you PMQ, that was vitally necessary...
Im gonna pick one of these up at some point and time and wire it up...
The one that Jason posted was a little too high pitched for me.....
jamesmost
actually 3 sets, forgot i have 2 sets up front and 1 set where the rear horn used to be just different tones and louder, when i hit my horn it is ususlly because i am moving fast and really want the person that is about to do something more stupid than what i am doing to know i am comming down the pike
