Installing AFtermarket Tach Into RB25 S14
FinkenS14
Car: 1995 Nissan 240sx S14
Where would I go for the signal wire?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Pin # 7 on the ECU.
If you do not have any signal there, you will need a Dakota Digital Tach Adapter box, then you will need to grab signal from the coils
FinkenS14
OK i looked at pin #7, its the yellow and blue wire correct? I tapped my tachs signal wire into that, and got nothing.
This is the tach im using BTW
http://www1.autozone.com/autoz...51724
FinkenS14
OK, so I found this.
Im going to try the resistor trick. Ill let you guys know
zerothread?id=385745
