duffman1278 »
https://forums.nicoclub.com/duffman1278-u61344.html
Fri Apr 18, 2008 1:24 pm
You didn't do much reasearch did you? Anyways, why would they make it so you need special brackets or any other misc stuff. All they do is use the OEM's dimensions, or as close, and just make it thicker, with different material, there's not different other wise, unless you got a radiator from a different chasis.
