on the vehicles without the navigation, it doesn't come off, it's part of the unit. I think you could get the one with navigation to come off, but you would need the wiring harness to make it work... not sure how you would set that up...ssjones wrote:Hey, while your car is apart: any chance you could take a peek at the AUX input on the front of the head unit? I'd like to know if that unscrews or comes off the back of that mount point. If so, I'd like to reroute mine under and inside the dash cubby to hide the input to my XM Ski-Fi2 radio.
SHIFT_COUPE wrote:You'll need this:
http://www.installer.com/item/...-NI12
and this:
http://www.installer.com/item/...-7552
I didn't know what to hook that blue wire up to, so i left it alone. Hasn't been a problem yet! If anyone else knows, please enlighten!98frontier_islander wrote:i bought the harness,now i bought the antenna adapter,i pretty can wire everything but on the adapter where do i hook up the blue wire?i connect the plug into the aftermaket player but confused with the blue wire,i know its a remote for the antenna.
definately not true.. mine is NOT connected, however, the blue wire from my aftermarket deck iIS connected to the correct wire on the factory harness... I can't recall exactly which one it is, so maybe that's why my radio is receiving signals ok!98frontier_islander wrote:i heard if you dont connect the blue wire, your radio am/fm wont work cause its not being activated,but if you still recieved signals without it ill try it out.
well all i did was for the antenna the blue wire connets to the blue wire to the aftermarket player the antenna REM,so that problem is fixed, now i have a flashing light on my instrument panel and its the supplemental air bag warning light.rjdmmfl1 wrote:
